Can't connect Home Speaker 300 to my Windows 10 computer
I just bought a Bose Home Speaker 300 and am trying to set it up for the first time.  I want use it as an alternate speaker for my PC.  This is how I tried to set it up:
1) I plugged the speaker into an outlet and waited for the indicator light to glow steady red.
2) I went to my PC and clicked on Settings --> Devices --> Bluetooth and other devices.  I turned the Bluetooth switch on and clicked on Add Bluetooth or other device.
3) I went back to the speaker and pressed the Bluetooth button until the indicator light flashed blue.
4) I went back to my computer and waited for the speaker to appear in the list of available Bluetooth devices.
5) When Bose Home Speaker 300 appeared, I clicked on it.  It was successfully paired with my computer.
6) I clicked on Sound Settings in the Related Settings section.  I then clicked on Sound Control Panel.
7)  In the pop-up window, both my computer's regular speaker and the Bose speaker appeared, but the Bose speaker was listed as disconnected.
I right-clicked on the Bose speaker and clicked on Connect in the pop-up menu.  The speaker emitted a tone and for a moment seemed connected.  But the connection was immediately dropped and the speaker remains virtually disconnected.
Could you please show me a way forward on this?  I would be very appreciative!
                                                    Thank you,
                                                     Michael Klein
Well, what do you know!  I tried the process again and this time I was able to connect the speaker to my computer.  The only problem is, no sound comes out of the speaker, but that is a separate issue.
I seemed to have figured it out, thanks to a Bose help article.  I pressed the AUX button on top of the speaker and virtually removed the speaker from my computer. I pressed the Bluetooth button and added the speaker to my computer.  That seems to have done it.  Why all this should be necessary, I have no idea, but at this point I don't feel like asking anymore questions.  As long as it works.
