CC-1D Update is failing every time
CC-1D Update is failing every time when I am doing through CSD 5.8 version .
CC1d is connected over POE near to switch .
Can somebody guide for any  configuration settings .
Hi Nettemravi,
What is the failure message that it gives you?
If you're using DHCP and a DHCP server, try setting this to a static IP, and set the PC network card to the same static range. Then try updating.
The other possibility is that you have a firewall that is blocking the ports used for updates. Please turn any firewall off during this process.
ChrisJ-at-Bose
Hi Chris ,
I can able to change ip address ,IP Address is static only and Laptop is also in same series .
It is showing - error 18 while doing firmware update  .
Ravi .
Hello,
I had this same issue.
This helped for me:
- Connect your pc cc1 only to a small POE switch
- update the via the Bose discovery tool (not CS designer)
- set the IP adress if needed
Then it will work fine, you can put it back on the controlspace network
