Hi i tried to connect CC-64 control center. The device is shown in CSD and i have also updated firmware as well. so the only problem is that all settings in properties window and banks are locked and i cant change or modify anything i need some help thank you
Hello RumenHristov,
Do you seen "Locked" in the Display of the CC-64 when controlling? In that case there is something in the design file that is set to lock the CC-64 (like in a parameter).
Hello..,,,
Thanks For Sharing this...... LiteBlue USPS
Access to the CSD may also be restricted if it is left open after abnormal termination of a CEDA, CEDB, or CEDC transaction.
