I have five cc16 panels installed. One of them when i´m changing with select button a star infont of the set, just like cc64 before you activatre the program. Why´s that there? I want thatt cc16 to change direct like the others.
Best regards Martin
Hi Martin,
It’s probably because the selection timeout is active. This allows the user to go directly to the source they want, rather than audibly stepping throiugh each one.
To revert the CC-16 to instantly switch source as you step through you need to set the Selection ‘Timeout’ in the CC-16 properties to '0’
Best regards
Rob
Hi Rob.
Thank you for the answer. Now everything works just fine.
Best regards.
Martin
