jpmag
February 29, 2020, 8:20am
1
hello
I have 2 L1M2, one T8s and one T1s
Is it possible to chain the 2 mixers, for exemple mixing a drum set in the T1, sending the output to the T8s which is connected to the L1 ?
May be a problem with the power suppy of the T1 ?
This would be great to extend the entries of the T8s ...
Thank you for your answers
jpmag
st-pro
February 29, 2020, 8:22am
2
Hi, jpmag.
Thanks for asking.
jpmag posted:
hello
Yes.
You'll need a T1 ToneMatch® Audio Engine Power Supply for the T1.
jpmag
Here's an article with all the details.
T1 to T8S ToneMatch Mixer
Does that help? ST
Plug the power supply from the T1 into the L1 base and it's output into the T8 AUX in, 9 or 10
st-pro
February 29, 2020, 3:31pm
4
Hi Cowboy Upp,
Cowboy Upp posted:
No - Do NOT connect the T1 ToneMatch® Audio Engine Power Supply to the L1 Power Stand. There's no reason to supply power from TO the Power Stand.
You will likely damage the Power Stand or the Power Supply.
Yes, that's one option. You can also connect to one of the main channels, 1-8 depending on how you want to control the mix (on the T1 or the T8S). There's lots of detail in this article. T1 to T8S ToneMatch Mixer
Of course I meant the T1 cable into the L1 base for heavens sake! Common sense, sorry for the confusion
st-pro
March 1, 2020, 9:23pm
7
Hi, Cowboy Upp.
Cowboy Upp posted:
There are a couple of options:
Connect each ToneMatch mixer to each L1. (4 channels to one L1, 8 channels to the other L1). Each sound source (e.g., drums) goes to only one L1. Super simple, but that doesn't sound like jpmag wants thisjpmag posted:
hello
jpmag
Connect the T1 to the T8S and connect the T8S to both L1s If you
Connect the T1 to an L1 for power ) L1#1 (ToneMatch Port), as you suggested AND Connect the T1 to the T8S Connect the T8S to both L1s -> (Analog Inputs) L1#1 and L1#2 => The signal from the T1 will go to L#1 via the ToneMatch Port and the Analog Input - this can lead to very strange and typically unwanted outcomes.
