Our church is considering adding a second BOSE L1 to our "outdoor church" setup this summer. Last summer we used a BOSE T4S mixer into a BOSE L1 Compact. Then, we used the LINE OUT jack (on the back of L1) to get the mix to the LIVE STREAM. It worked beautifully!
In adding a second BOSE L1 COMPACT, would we simply insert that into the signal path as follows?...
T4S into L1 Compact #1...then LINE OUT of L1 #1 to Input 2 of BOSE L1 #2...then, LINE OUT of BOSE L1 #2 to the LIVE STREAM. Do I have correct?
Our goal is simply to get greater coverage throughout the parking lot (although, even with one L1 Compact last summer the coverage was adequate). We want the exact same mix (content) coming out of both L1's.
Here a few lingering questions (that is, if the above is correct so far)...
- How far can I (or should I spread the two L1's apart from each other). Is running 50 feet of cable feasible if we use a TRS cable? Or, should we position them closer together and just point them in different directions to try to accomplish greater coverage?
- Will the LIVE STREAM mix work the same (coming out of the 2nd L1) as it did last summer coming out of just a single L1 (and it worked great last summer).
- In checking your website, it looks like the L1 Compact is still available for purchase. I assume that would be the best way to go as it is the same as our current model.
Many thanks for your help.
Steve
Bose product name
Country
