I bought 2 Bose L1 compact, 2 Bose S1, 1 Bose Sub1, and Bose T8s. Can someone help to layout the connections for my system to get the best sounds out of them for a mini live band? Thanks in advance!
Hi aipham66!
There are a few different ways you could arrange this setup.
Would you be using the S1 Pros for separate monitor mixes, or to play the same master mix as the L1 Compacts?
I’d like to play the same master mix as the l1 compact but which one better? Thanks!
Hey aipham66,
Thank you for confirming - in that case, I'd recommend the following setup:
Thanks you much!
Hi Dylan,
For step #3 from your instruction, would it be the same result if I connect the Line Out on the L1 Compact to the Sub1 bass module? Thanks!
Hey aipham66,
Yep, it would be! On the L1 Compact, the line output is labelled 'Main (Bal/Unbal).
Thank you!
Hi Dylan_R,
I'd like to change my setup as follow:
Would it be any problem with this setup as far as sound quality overall?
Notes: I have only 2 Shure SM58 microphones connect to input 1 & 2 and Yamaha SX900 keyboard to input 9&10 on the T8S ToneMatch. This setup is in my 400 sf rectangle shape family room.
Hi aipham66!
This setup would be absolutely fine, so long as gain staging is correct throughout and nothing is peaking/clipping.
