Hello!
we are a jazz-pop band consisting of: electric drums or drums, electric bass, flute, cimbalom, voice. I bought two L1 mod2 systems and we want to know how we connect this system to one of these mixers: Line6 or Midas M32R. we would like to buy 3 Bose s1 for monitoring when needed.
we will reach an audience of up to 300-400 people. club, theater, avenues
thank you!
Marius Mihalache
Hi, Marius.
Marius posted:Hello!
Thank you for this information. It's nice to get to know you. Do you have a picture of your band?
Congratulations!
thank you!
Marius Mihalache
You can use cables like this from the mixer
to the L1 Model II Analog Input settings
and S1 Pro system channel 1 combo input - See S1 Pro Mixer Settings
Line 6 mixer
Midas M32
Thanks for the reply. I played on a similar system and I really enjoyed the sound. if I need more bass, I can attach extra bass.
thank you!
Hi Marius,
Happy to help.
When you get your L1 Model II sytems set up, please share some pictures of your band in this discussion: Gig pictures!
Thanks!
sure ... if you have any other configuration suggestion, please tell me, please!
ST,
Just purchased a Midas MR18 mixer to use in a 5 piece country band using 2 L1 model 1S with B2 bass. I also perform as a duo with another band member and we use either a compact or one of the larger L1 depending on room size (we play mostly restaurants). We also use backing tracks that are in stereo. How can we get L & R of the tracks and output from the Midas to 1 Bose unit?
Thanks.
Steve
Hi strayhix,
Welcome to the forum!
The L1 model 1S, L1 Compact and L1 model II all play in mono as each system has one speaker array.
If you are only using one Bose system, the left and right output channels from the mixer will be played together through the speaker in mono. The simplest way to achieve this setup would be to use a 1/4" TRS cable connecting from the headphone output on the Midas MR18 into the input on one of the L1 systems.
For true stereo on stage, you would require two L1 systems. With this setup, you can use two XLR cables to connect from the main L&R outputs on the MR18 into each L1.
Thanks Dylan, it did indeed help.
