Hi everyone. I am new to bose and I need help to wiring my bose 802 ii speaker with 802 c controller to my receiver. My receiver is http://singmixers.com/bason-ba-6800-10-channel-equalizer-1400w-professional-karaoke-mixing-amplifier/. Anyone know how to conncect bose to that receiver, please help me. Thanks alot
Hi Vinh,
The receiver you mentioned seems to be missing an insert loop, so you would have to go with only one source at the 802C (or connect a standalone mixer to it).
So this would be Source -> 802 C -> Amplifier/Receiver -> 802 II loudspeakers.
Also this receiver is using RCA inputs when more than 1 channel is needed. If mono is what you want this will not be a problem. (technically you can use adapters, but it's not recommended)
So as it stands right now, your only option is to use 1 source and 1 channel of EQ with that receiver.
My suggestion would be to purchase a mixer, but note that you won't be able to use many of the features on this receiver either way.
ChrisJ-at-Bose
Dear Vinh as my colleague Chris replied there are not many solutions one thing you can try and connect the 802s without the processor by setting an equalization curve in the main panel Greetings Kamil Barca
