Connecting 2 S1 Pro
Hi!
I have two S1 Pro speakers and I want to connect them while I sing and play my guitar through it!   In the manual it says that I need a 1/4 inch TRS cable for that (not an ordinary guitar TS cable).
I have problems finding a fairly long TRS cable at all and they seem to be very expensive!
Any suggestion where to find a 2-3 meter long TRS cable at a fair price!
Thanks/Daniel
Hi Daniel,
I've had good experience with this vendor Audiopile.net
EDIT - I'm sorry, it looks like you're in Sweden. Audiopile is in the USA. I don't think they ship overseas.
Hi again Daniel,
While a 1/4 inch (6.3 mm) Tip-Ring-Sleeve cable is preferred, if the distance is less than 6 meters, you'll probably be okay with a Tip-Sleeve instrument cable.  If you have a cable like that handy, give it a try. If you don't hear any line noise, you're fine.
If using simple TR cables doesn’t work, one option to perhaps consider is using TRS to XLR cables. You could get 2, short TRS to XLR cables (one with female end one with male end). Then connect the two short cables using a longer, standard XLR mic cable (which you may already have) if you needed the extra length. This way you could use varying lengths of standard XLR-XLR cables as needed.
In the US, 5 foot TRS-XLR cables are $25 each, so not all that cheap a solution, but just throwing it out there.
I have been using Monoprice in Norco California for decades. Their cables are heavy duty and not pricey at all. They do mail order or pickup from their warehouse.
I see a TRS to XLR (male) 25' long cable on Amazon for about $15.  That's the kind of thing that I use when interconnecting my 2 Bose S1s directly.
Maybe something like that is available where you live.
