Connecting a Sub2 with a Sub1
pro 32 sub match to sub2.  I want to submatch/link 2nd cable to Sub1.  What would the phase settings be?  How about Line Out HPF on each sub?  Should volume of two subs be set at same gain?
Hi wweiss!
Up to two Sub1 or Sub2 modules can be powered from a single L1 Pro system using the bass module's 'Submatch Thru' port.
The other settings you mentioned would be dependent on your setup.
What is your audio source, and how do you have it connected to your L1 system?
Where do you have the Sub1 and Sub2 located in relation to each other?
In my instance I’m a solo performer (sax, keys, and backing tracks via MacBook Pro) using a T8 into the L1 Pro 32 (Sub 2). Just bought a Sub 1 for smaller gigs. I don’t if would complement the system to run them both at once…but wanted to know the settings if I did. And if cardioid mode would be an option also. I’m totally new to the active sub game. I was previously using a L1s system with the B2 sub. Any help is appreciated, thanks in advance.
For cardioid, you need matching Subs
