Hi Phil,
I noticed your post in the Ask Bose for Help forum.
Phil posted:just bought L1 1S B2 plus a Tonemaster T1
Question re T1 cabling for connecting an iphone for backing tracks -I am confused, internet search and manual are contradictory.
1.Why can't I simply use the 3.5 mm from the phone and connect to input 1/2 or 3 via a 1/4 stereo jack
2. Do I really have to buy a new cable to connect 3.5mm from phone to 2x 1/4 inch mono jacks into channel 4/5. Also, on this point some of the internet stuff ( Bose sponsored video) shows 3.5mm jack ending in 2 phono connections.
It is much simpler connecting to my Fender Passport Pro
Regards
Phil
It sounds like you have read this note in the Bose Pro Portable PA wiki.
I've just added some more information to that article that addresses your questions.
The output from your iPhone is stereo. The T1® inputs 1, 2, and 3 are mono.
If you use a cable like this
you will probably hear only the LEFT side of your stereo signal from the iPhone.
Set your iPhone to MONO
If you set your iPhone output to mono, then you can connect to T1® channels 1, 2, 3 with a cable like this and hear both the LEFT and RIGHT sides of the stereo signal.
Launch the Settings app on your iPad or iPhone.
- Tap General.
- Tap Accessibility.
- In the Hearing section, turn Mono Audio On
Now both sides of the stereo output will have a mono signal (both LEFT and RIGHT channels combined).
You can connect the mono output to a mono unbalanced input like T1 ToneMatch® Audio Engine channels 1,2,3.
This does not apply to T1 ToneMatch® Audio Engine channel 4/5. The channel 4/5 inputs are balanced mono and not compatible with a stereo signal (or a stereo signal that has been mixed down to mono from the iPad or iPhone).
If you set your iPhone to mono, you don't need a new cable.
T1® channel 4/5 is designed to accept the LEFT and RIGHT sides of a stereo signal and combine them to mono. You can use a cable like this.
connected like this.
I have updated the notes in the wiki to include the information above.
