Connecting L1 model II to zoom L12
I'm wanting to connect my Bose L1 to a Zoom L12 so i can record live shows without noise interference from the audience. I also have  a T1 to connect through. I just cant figure out how to make this work.
Hi c21randy,
Welcome to the Bose forum! Thank you for joining us.
Where is the Zoom L12 located, in relation to the L1 and T1?
If possible, I'd recommend the following setup to give you the most options for recording and mixing (and also to record/mix in stereo):
  1. Connect your microphones/instruments directly to the inputs on the Zoom L12.
  2. Connect from the outputs on the Zoom L12 to the T1/L1.
Thank you so very much for your guidance.
