Connecting S1 with L1 Compact
Is this possible to connect mi S1 with the L1 compact? And how I have to do. Many thanks for your help.
Hi DJ uuw,
DJ uuw posted:
Yes, you can.
You can go either way depending on what you are trying to do.
  • Sound source(s) to the S1 Pro, and the S1 Pro to L1 Compact
    • Connect the sound sources to the S1 Pro
    • Connect the S1 Pro Line Out to the L1 Compact channel 2. Set the L1 Compact ToneMatch switch to Line Level.
  • Sound source(s) to the L1 Compact, and L1 Compact to the S1 Pro
    • Connect the sound sources to the L1 Compact
    • Connect the L1 Compact Line Out to the S1 Pro (either channel). Set the S1 Pro ToneMatch switches to Off.
Either way, use a 1/4 inch (6.3 mm) Tip-Ring-Sleeve cable to connect the two systems.
