Connection with a DJ controller
Hi,
I recently purchased a Bose L1 model 2 with 2 B2 and two Tonematch T1 and T8s.
I also have a dj controller (pioneed ddj sr2) who has 2 xlr connection.
I was wondering how I can connect my DJ controller to the Tonematch T1 and T8s?
Many thanks,
Hey Rodrigue,
Welcome to the forum! Thank you for joining.
The DDJ SR2 can be used with either the T1 or T8S, by connecting 2 XLR cables from the master out on the DDJ into the input channels on either mixer.
One thing to note - the T1 is a mono mixer, so the output from the DDJ will be summed to mono if you are using this mixer.
To retain stereo balance from the DDJ's output, ensure that the same volume level and processing settings (EQ and FX) is used for both input channels used on the mixer.
Hi bcav,
To achieve this stereo setup over Bluetooth, you would need to:
  1. Connect your computer or phone to one of the S1 Pro speakers over Bluetooth.
  2. Pair the two S1 Pro speakers in stereo by following these steps.
  3. Connect the 'LINE OUT' on the S1 Pro speakers to the inputs on the Sub 2 bass module.
Hi, Whats the best way to connect two S1 Pro speakers for left and right sound with one Bose Sub 2 to play music from a computer or from a phones bluetooth?
Thank you!
