Greetings Bose Community!
I just purchased the the T8s mixer but i'm a little confused on the proper setup for my gear.
RCA to L R 1/4" inputs from mixer (main mix)
1/8" to L R 1/4" inputs from laptop for Spotify (filler/backup)
XLR to XLR from Shure Wireless Mic
XLR to XLR from Shure Wired Mic
Also want to have a record out available for videographers or to record my mixes while i'm using the main XLRs
Using (2) F1s or (2) L1M2B2
Any advice is greatly appreciated!
st-pro
2
Hi Cory,
DJ Cory Barron posted:
Congratulations!
Please make sure you are running the latest firmware. See:
T8S Firmware Updates
Please tell us more about this connection. Do you have another mixer with RCA outputs? Please give us a link to the owner's manual.
Consider using the USB to PC connection (find this under Prefs on the Rotary Selector).
Please see: USB B from PC
For both of these, please see: Gain Staging
Use the Aux outputs. See: Aux Outputs
For the F1 Model 812 systems see;
T8S to F1 Model 812 Tip Ring Sleeve Connection
T8S to F1 Model 812 XLR Connection
For the L1 systems see:
T8S to L1 Model II
That should get you started. Please tell us about the device with the RCA connections mentioned above.
