Hi,
I can Ping my Dante End Point Bose EP22D on my Laptop. But its not showing Either on Dante Controller or Control Space Designer. Any solution? It's a switched Fiber optic Network. End points are 100 meters away from Server Room.
Hi,
Hi Amol,
In order for the EP22D to have a static IP address now, I assume you were originally seeing it in Dante Controller or ControlSpace Designer. Did the problem happen just after setting the new IP and rebooting the device?
Possibilities:
-It's sharing the same IP address as another device on the network. Try to isolate it from other network devices or bridged networks. If it becomes visible, change the IP to a unique address.
-If it can't be pinged after isolating it from other network devices, it's possible that it's still in DHCP (default mode), and it was another device using 172.21.103.151 when you were pinging. Try a DHCP server in this case.
-Antivirus software on the laptop could be blocking the ports used by Dante Controller or ControlSpace Designer. Try adding them to a list of trusted applications.
If these do not help, please let us know a bit more detail.
Thank you,
ChrisJ-at-Bose
Mr. ChrisJ,
Thank you for your reply.
I have already tried this. When I connect that same device to local Network switch then I can control that device on dante controller. But Same device I put on fiber optic network its starts pinging but not visible on dante controller.
We are using a network where thousands of DHCP and static devices are connected in a network. I think its a problem of Network only. So now I have decided to separate our Network For Dante Devices only.
Hi,
How I change the EX-4ML IP add ??
Hi Goran,
Just use Dante Controller. 'Device View'>'Network Config'. Change to 'Manually configure an IP address', and enter the desired info. Then reboot it.
ChrisJ-at-Bose
Mr. ChrisJ,
