My S1 is not working when plugged in. It will work on battery. When plugged in, it will go on for a few seconds or maybe a minute or two then just shut down - power light goes out too.. tried it many times. It WILL work on battery and the battery seems to charge between sets
This only started yesterday at my gig and brought it again today hoping it was a fluke. Still shuts down and can't be used plugged in. I'm pretty sure I saw the input light go to a steady amber with no signal going into the respective channel
If that doesn't help, you'll need to call Bose Support.
Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only) Monday-Friday: 9:00 AM - 9:00 PM ET Other regions
tomdavisdotcom posted:
I thought that for sure would work, but it didn't. I reset a second time and thought it was working but after a half hr it started shutting off. Every few minutes it would spring back to life. This was while plugged in and also when on battery. Now I gotta find my receipt ... Less than a yr old for sure
