wrote:
Got the information from an disassemble video on Youtube:
Whats inside a 700 Soundbar Bose soundtounch 300
Thanks I'll check that out 🙂
wrote:
Also some other manufacturer added the ability in their HDMI 2.0 interfaces.
See also an article in German:
HDMI ARC und eARC: Alles, was du wissen musst
There is a paragraph in it which is translated as follows:
"But there is good news: even soundbars and televisions that only have an HDMI 2.0 connection can ideally use the advantages of eARC - often even with a subsequent firmware update."
It also goes on to say "all connected devices must be fit for eARC". So if there is a device, be it a single chip that interfaces with the HDMI signal, even outside of that single one you mentioned, then that system is not compatible with eARC and it cannot be updated.
I would also point out that "For example, manufacturers such as Yamaha, Samsung and Sony have published eARC updates for various televisions" was not for everything that they made from 2016 onwards. Far from it.
It was for products they specifically designed to be upgradable to eARC: "the eARC portion can be added now to some HDMI 2.0b based devices via a firmware update, provided manufacturers have made this part of the equipment design."
You will notice that the minimum release year for an ARC to eARC firmware update from those announced products is a release date of 2020... Not 2016:
Samsung TV's & Soundbars - All released in 2020 & 2021
- TV: UHD TU7000 and above models.
- Soundbar: Q70T and above models.
Sony TV's - All released in 2020
- 4K LCD TVs - X900H (US) / XH90 (Europe)
- 8K LCD TVs - Z8H (US) / ZH8 (Europe)
Yamaha Receivers - All released in 2020 & 2021
- RX-V4A, RX-V6A, RX-A2A and TSR-700
wrote:
If they don't want to support it on older hardware
The internet LOVES conspiracy theories. I have some hardware experience so I know that upgrading and adding a new feature is sometimes physically not possible with the architecture already on a system. In this case, it does not look like the system can be made to support eARC.
One good way to tell is by looking at what Bose currently sells. If it was possible Bose would have done it for their $4,000 Lifestyle 650 system that is currently on sale and also came out in 2016. Though I have no clue if it has a similar chip inside or not.
But as I cannot find any companies that have an ARC to eARC firmware update for a product that was first manufactured in 2016... it's not a good sign that this is possible with the installed architecture from that time period.
wrote:
then they should at least make comparable products so that we can switch.
Regards
Bose currently sells the Soundbar 700 & 500 and both support eARC as they came out in 2018.
