I own two set L1 compact speakers and sastified with the sound when I played live music indoor. However, they seem not enough bass when I played outdoor. Due to versatile setup needs & cost, I don't not want ugrade to L1 system with B2 bass instead buying one F1 powered subwoofer when playing out door. Can someone advise if F1 Powered Subwoofer is compatible with my two L1 compact speaker or can be setup for my intention?
Usually, you will leave the Polarity set to NORM. If you find the bass seems weak (could happen depending on the distance between the F1 Subwoofer and the L1 Compacts) try the Polarity set to REV.
