Feeding a T1 Tonematch into Another T1
I have used the T1 for 3 vocals and a ukulele, into L1 Compact, with separate amps for guitars and bass.
I recently bought a used L1 model 2 with B1 and another T1.
I want to try feeding the first T1 output to channel 4 on the second T1, and run 2 guitars and a bass into channels 1-3 on the second T1.
I assume a TRS cord from aux or main into the other channel 4 will work? Any advice?
Hello cc407,
Yes, use a TRS-TRS cable; you have the concept exactly correct.  You can find an illustration in the T1 ToneMatch Audio Engine section of the Bose Professional Portable PA Encyclopedia at this page.  Just substitute your Model II (using the ToneMatch cable) for the Compact (which uses a TRS cable.)  Also, you obviously won't need the second T1 power supply pictured, since power is supplied from the Model II via the ToneMatch cable.
Thanks. It worked fine
