L1 Pro 32 & Tonematch T4s
Firmware Ver for Tonematch v 1.1.4
When you dial into into Prefs on the T4s and then scroll to L1, whether you are successfully connected or not, the T4s will inform you as follows: NO CONNECTION. I was informed by tech services in Philippines that this is a firmware glitch that requires correction. This "glitch" caused me great frustration as I was trying to get a good connection between the two devices, which I have posted about twice earlier.
I've got two questions:
1. How could a world class manufacturer of electronic goods put out into the marketplace one of their most expensive products with a glitch like that?
2. When will Bose fix this glitch with a firmware update?
Thanks... Mitch
