After a few years of service, one of my speakers started to rattle. Has anyone had success getting it repaired?
Hi Gleb,
Gleb posted:After a few years of service, one of my speakers started to rattle. Has anyone had success getting it repaired?
I'm sorry you're having a problem with the F1 Model 812. A rattle might be a loose grill. The grills are pressure fit at the edges. (Don't press in the middle).
If the rattle is inside the unit, you can send them into Bose for repair.
(U.S. and Canada only)
Other regions
Give them a call.
I wanted to follow up. Turns out it was just a cable issue. Didn't have to send anything out. Thanks for the reply!
Hi, Gleb.
Thanks for coming back to tell us you solved the problem.
Enjoy the music.
I have a F1 812 flexible array loudspeaker that there is no sound when turned on no heat coming from the amplifier how can I send it in to fix it and what’s the repair cost it looks like if the amp inside gave up
Hi DJBlazer509!
Sorry to hear you're having trouble with the F1 812. For info on available service options, I recommend getting in touch with your local Bose support team.
