HDMI not found on tv
Bose product name
Bose soundbar 300
Country
Uk
Unknown
Unknown
Samsung smart tv
Sound bar working fine for over 12 months with HDMI. Now all of a sudden tv can’t find the HDMI where the sound bar is plugged in. Tried moving bar onto another tv and still can’t be found. Works ok using optical or WiFi.
5/6/2021 working fine for 12 months or more
Tried unplugging and leaving turned off then reconnect with no joy
Possibly the HDMI port has failed.  However, first I would try a different HDMI cable.  You could also try a factory reset of your Bose.
How would I do a factory reset?
Hello Ste Tonk and thank you for reaching out.
I can certainly help with that! To factory reset your soundbar, you can follow these steps on our support website here.
If you have the older SoundTouch 300 soundbar. You can follow these steps instead.
I hope this helps!
