Recently I discovered a problem with my T4S Headphone jack. I only get sound when I insert the jack partway. If fully insertedthe sound is soft and distorted. Is there anything I can do to remedy this or will it require a repair?
thank you,
Takefive
Hey Takefive!
Does the issue occur when using different sets of headphones?
I recommend using a different 3.5mm to 1/4" headphone jack adapter too, in case the one in use is faulty.
thankyou, yes I should have mentioned that I tried an alternate headset, same result
My apologies, The headset has a mini jack and i was using an adapter, I changed adapters and had same problem. I then changed thenheadset and it is good, the mini jack must have been the culprit. Problem resolved. Thank you
