Help Needed - Connecting LT9403
Hello,
I could use some help. I picked up a Bose LT 9403 Loudspeaker and would like to connect it to my system but I just don’t know what I need (rookie here). I have a Numark iCDMIX3 mixer and 2 Harbinger VARI V2212 600W 12" Two-Way Loudspeakers. I believe I need a controller and/or amp to connect the Bose to my system. I assume I also should run the 2 Harbingers through the same system to connect to the mixer. Can I please have some advice and suggestions to get me going? Thanks so much!
Hello, first of all to connect many types of different houses you should have a DSP that manages them otherwise you have good speakers but you can't make the most of them then separate amplifiers to manage them if you need help just ask hello Kamil Barca
