Hello again, kreppy30,
Unfortunately, there is no "quick setting" that I can suggest, as my ears (and obviously, location) are so much different.
Knowing the particular model of Peavey mic that you have may be helpful, but note that the Pro 16's internal settings are not mic-specific, so choosing a mic in the ToneMatch settings on the T4s will obviously be different than if you leave it "flat".
If you are using the System EQ presets on the Pro 16 (Off, Live, Music, Speech), here are the settings that it uses (thanks to Dylan_R at Bose in this post. (One thing I forgot to mention earlier: The System EQ preset does not follow to the Line Out jack, just the treble, bass, reverb and any settings you might make on your T4s. )
Here are some notes on changes in the System EQ settings:
LIVE – slight reduction in 100Hz, bump around 1KHz, slight reduction at 10KHz
MUSIC – increase around 100Hz, increase around 10KHz
SPEECH – reduction between 100Hz and 500Hz, bump around 2KHz-3KHz, bump over 11KHz
You should be able to approximate these settings using the Para EQ for your mic channel. Just make sure you have properly gain-staged your mic (instructions here). That's a step you don't have to do on the Pro 16, but almost always on any mixer.
Then just volume, zEQ and Reverb to taste ... take your time, experiment, but most of all, enjoy! I know it took me years to "dial in" what I wanted (once I got my first L1 system, it became easier to do.) Some folks get it quickly, others take longer. It's all OK!
Remember also, what you hear in your head is different than what you hear when you record yourself (videos or audio recordings) and that's OK too! (The quality of the recording and the playback device[s] will matter as much as your performance.) Whether you try to mix for your audience or for yourself, don't get fixated on one or the other. Concentrate first on your performance, to the best of your ability, and the equipment will enhance it!
