How do I use the legacy T1 Tonematch with the new L1 Pro16?
Bose product name
Country
Hello H2oloo64,
The following article explains the compatibility in detail.  The short answer is the T1 can receive power from the L1 Pro using the ToneMatch cable but the audio signal must travel over a different path.  If you currently use an external power supply for your T1 mixer, then nothing should really change for you.
https://toonz.ca/bose/wiki/index.php?title=T1_Compatibility_With_L1_Pro_Systems
Hope this helps.
