I need more inputs
Hi All, I'm doing a charity gig in a couple of months time, in a small venue.
I'll be using My Li / S1/ B2 system with Ti Tonematch.
there's a variety of acts performing that night, mostly solos and duos.
But there is also a Trio who use 3 mics plus guitars.
It's a one off gig so I don't want any added expense, so how would I connect an external mixer to the T1 ?
Eddie
Just read that channels 4/5 would be ok for a mixer. !
If that's the case then I would plug the ipad (currently in 4/5 ) into the mixing desk and 3 mics to 1'2'3'.
Would that work ?
Eddie
Hi Eddie,
weeo posted:
Would that work ?
Eddie
Yes that should work OK. I would however pan the instruments to one side (left or right, it doesn't matter) and then take a cable from the main out on the side that you have panned to and connect this to 4/5. You would then need to select a neutral preset for that channel. I would try UTILITY FLAT for this purpose.
Don't forget to set the trim on channel 4/5 of the T1 when using an external mixer to make sure that you have enough signal to work with.
If you can have a trial run beforehand all the better.
Has this helped in any way?
yes Tony a great help and assurance. Thanks for your help, i'll be trying this out at the weekend and i'll let you know how I get on.
Regards
Eddie
