Input meter moves
With out anything connected to channel 2/3 the input lever meter is moving. Does anybody have this problem.
Hi jermsguerrero,
I just double checked my T1® and the input meter does not move on any of the channels unless there is a signal present.
I curious - do you hear anything from channels 2 or 3? Is there a sound?
If you are hearing something even if the channel 2 and 3 trims are all the way off and there is nothing attached, you might need to have the T1® serviced.
You can check in on that by posting a note in the Ask Bose For Help forum.
