If you could have anything you want in an L1® ...
Ask, even if you don't think it's possible. It wasn't that long ago that the L1® was impossible.
Have fun with this.
Feature Requests
Have fun with this.
Feature Requests
What I would like in a nextGen L1 compact, based on my current position of being an experienced live sound engineer yet very new to Bose Professional products, listed in order of priority:
Regards,
Bruno
For all L1 family products:
For just the Compact:
more channels on the tonematch!!!!
This reply is my suggestion from several months ago, received no comments - maybe my ideas are of no value, except that I think they are very good suggestions!
I'm an L1 Classic guy from Day One (PAS!), have and continue to use two of the original units. Bought a T1 its day one also, but didn't care for it and sold it. THEN, bought an early SoloAmp - GREAT design and implementation.
L1 Compact? I resisted this for many years, because of so many shortcomings compared to SoloAmp electronics and options. I finally bought a used L1C couple years ago, and now a second one a week ago (many months ago now).
I like: small size, sounds like Bose. I dislike: most everything else (sorry). Mainly LACK of controls, connectivity, things like that. I HAVE learned to work around what I consider shortcomings (because its natural sound is so good), but this requires a lot of other gear and is a bit complicated.
I always: place L1C on a piano bench and use one extension, SO I can hear the base bass better, and so I can reach the controls reasonably.
SON Of L1 Compact? I would like to see:
0. I like the recent suggestions of having BOTH channels accept XLS, TRS or TS - with a very basic switch for each channel to indicate mic, guitar, or "00" preset.
1. Make one extension 6" longer and one 6" shorter - same total length, but more flexibility for different usage situations and rooms
2. Separate channel Line Out, preferably XLR, but TRS would be ok
3. Master Volume / Mute Switch
4. A few simple basic reverb choices, independent but applicable to both channels --- if NOT this, then insert/return separate for each channel so we can use an external fx
5. An insert connection for a guitar tuner, with mute
6. A port for T1, even though I don't want it - omitting that was not smart
*** 1-6 above SHOULD be included in the $1,000 base price, in my opinion - this is basic, needed connectivity (Solo has all this and more.. just sayin)
*** I would pay extra for:
7. Extension(s) WITH SPEAKERS, probably including a way to power 1 or 2 of them with the A1 power amp, or something like it
(my original annoyance with the L1C was the empty extensions - seemed (and still SEEMS) dumb, cheap, insulting to the user)
8. An optional REMOTE - even just like the old Classic would be fine, but better and preferable would be an iPhone App, like the QSC, Behringer, Mackie and others - this would be GREAT!
Thanks - LOVE my Bose stuff, my Bose SOUND!! MIKE O'
There are a few things I would like.
1. With a Tone Match, 6-8 Chan XLR combo, USB, Wifi and Bluetooth, sd card for recording or MP3 playback, fully adjustable eq on every band hi, mid low or a fully adjustable eq like what QSC mixers have. Better hall reverb. A app for iPhone to adjust mixer eq, level, effects and and name inputs.
2 in a Compact make a full array so it's easier to hear at sitting level. A connection for the T1 Tonematch (no power supply needed) Blue Tooth, wifi and an app tomadjust eq. A spot where the mixer would sit nicely.
1. An Fx pedal input to mute fx between songs.
2. Option of stereo out - for use with F1s
3. 6 - 8 channels - even if the extras did not have all the DSP functionality.
4 .Bluetooth
1) A stereo T1 with at least 8 channels and 8 independent outputs controlled by 1 master fadar/knob to have the ability to conect up to 6 L1 Model ll 4 minimum and control the entire mix and DSP's.
2) international voltage for the big models, we always want to perform overseas with them but it is not practical to take voltage converters, and it is practically imposible to find L1's for hire where we had to perform.
3) more power??
4) To have the ability to connect a small bose speakers as monitors whe you put the L1 in front of the band. Or maybe for the sticks to have speakers (4 drivers) on the back to make it possible to place them in front of the performer and be able to have monitoring as well?
I know they are meant to be placed behind the performers but what about when the audience is too loud and you need more power, you can't push them to much because of the feedback it creates when you have them too loud behind you.
5) iOS controlled ??
Our gear:
We have 2 L1 model ll B2 t1 and still have to use a QSC TouchMix 16.
The Compact is what it is but the idea of moving the array to the back and the control knobs to the front is the best thing I've seen on here. You generally looking back at the unit while performing and not seeing the lights overloading is bothersome. The controls are pretty basic but it would be cool to be able to reach them from the front rather than walk around to the side to monitor lights or knobs.
Leave the L1 stack controls behind the column.
change the connections on bass cables to tight angled connectors, then the cables coming out are not facing upwards producing trip hazards, also the cable facing out of the now horizontal connector doesn’t have the resultant stress point where cable meets connector which has raised issues with core breakage.
turn the speaking mount around so the speaking now faces the rear.
change the ethercon connector to a right angled connector for same reasons.
supply a right angled power supply cable which also benefits from above and reduces trip hazards.
In addition to relieving stress on the speaking cable and reducing trip hazard the speaking would also cover and protect the power but from inadvertent operation.
Changing to right angled speaking also protects the protruding cable at the back of the B2 bass bins.
with a cable straight out there can be a tendency for the cable to be bent against walls, bent or kicked or caught in the resultant loop of cable hanging out - again a trip hazard.
This is how my right angled swap out looks...
No stress on cable, less likely hood of core stress fractures, no cable loop to trip on or damage.
Could also consider changing airflow vent to fans on the sides rather than in the handle well.
over Xmas just gone someone kindly placed a pint on my B2 which vibrates off in the direction of the handle / vent well. I swiped it away as it fell and only had a small amount of fluid enter the well which I immediately put tissue into and soaked up. Had the well filled there is only one place the liquid could go.
Venting from the side would mean liquids would gravitate down past vent holes - not into them.
An alternative and simpler yet would be to drill holes in the bottom of the handle / vent well as it stands.
Bluetooth app providing full control of all T-1 functions on a phone or I Pad. We are constantly using Channel Mute, Effects mute, adjusting volumes, etc. during sets. Would be very cool to control the T-1 with an I-pad and Android compatible App.
Compact having a mounting location for Tonematch mixer. Wouldn't mind a battery powered option for the Tonematch mixer when used with the Compact as well... or at least power supplied by Compact ala L1 Model II
I've owned and used an L1 compact gigging with an acoustic duo for about 2 years.
As others have said, XLR line input or combo would be my #1 request. Also line array off the back not front.
Beyond that more mixer capacity but that would add cost. I've used the T1 and TS4 mixers with the L1 because I need 3 channels but moved to a tablet based system. Ideally you could make a mixer module that you could plug to the L1 or any bose system that had a tablet interface. I'd even suggest a propitiatory tablet that is part of the system.
Oh IMHO you need to have reverb with any mixer functionality (like on the S1).
Love my l1 products.
I own 3 classic, 2 model 2's, 3 compacts, 4 b1's, 2 b2's, s1 pro, and 2t1's
On the t1's, I could use more inputs, but the t4 does not have enough new features for me to upgrade.
Features that would get me to upgrade my t1's:
Bluetooth
1/8" input
iOS control
Headphone jack with monitor/cue capability
Keep up the great work!!
One single, simple thing would get me to upgrade my T1 to a T4 is an L1 bracket. Still can't believe they got rid of this. The biggest appeal of the T1 to me is that it goes directly on the tower, minimizing the precious floor footprint.
I love Bose L1 and L1 Compact speakers. Have used them for many years. I also really like my new S1 Pro's (ingenious)... I think Bose should be looking at a next gen L1 Compact similar in design and specs to the Electro-Voice Evolve 50.
A rack mountable version of the T4 and T8 would be nice.
I would love to see you create a new B2 Bass module that is just as efficient as the current model (or even more efficient), but weighs less. Because the current model is just so heavy. It would be nice to have a lighter model to choose from. I know you already have the B1 bass module that is lighter, but it isn't as loud.
Thank you for allowing us loyal Bose users to make suggestions, I really appreciate it! And I look forward to seeing what the creative minds at Bose come up with next!
Hi Everybody,
Thank you for your ideas and suggestions. It's a joy when people are using their Bose products and are so enthusiastic they can imagine ways those products can be better.
Although Bose can't comment on every suggestion or talk about future products or developments, please know - they are listening.
Thank you,
