Does anyone know how to connect T1 with 2 L1 classic. I just need to be sure not damage anything.
Best regards,
Sid
Best regards,
Sid
Hi Sid,
If you want the same sound coming from both L1®s, this is easy.
Connect the
DO NOT use a spitter out of the T1® to both L1®s. The sound from the two L1®s (especially the bass) will tend to cancel each other out.
All set?
Hi Sid,
I'm sorry your L1 Classic has stopped working. Yes, it's time to call Bose.
(U.S. and Canada only)
Other regions
ST- Thank you - i will call tomorrow
Dear Bose communities -
I need set up advise, I plan to use my L1 classic with 2 B1 subs and my new S1 pro with Behringer B1200D pro sub and T1, ( one of my L1 classic was sent out for repair 2 days ago.)
Instruments:
1 Yamaha PSR S950 arranger keyboard.
2 SM58 mics
1 Electric guitar with amplify
For fund raising party inside restaurant for 350 people ( 35 round tables - 10 people on each ) it's in one big square room - the ban is on stage - dance floor - the rest of space are tables for guesses.
- There will be some announcement before dinner start.
- The ban will play Soft live music during dinner.
- Dance floor will open after dinner
-Rock n' roll - country music - 60s 70s 90s -Beetles - Eagles - so on...
Thank you so much
any input will help - I don't want to rent or buy anything at this time I like to use what i have for now.
Hi Sid,
You can connect everything as you normally would with the T1 and the L1 Classic. Lets say you connect that to Channel 1.
Now you have two choices.
Choice 1
Choice 2
For step 2 T1 Aux Output, you will have to set up your inputs to route them to the Aux Output.
Take some time before the show to try it both ways. They should both sound fine. But you may prefer one over the other because of the way you control the volume.
@Sid , I use:
First, you need to find a way to clamp the gaps together. I would personally use ratchet straps. Practice with them first, as the Super Unix glue/gel sets relatively fast. The new bond will be by permanent.
Lashing straps are less expensive, but are a bit tricker in getting the clamping presseure:
Thank you,
I ordered that glue online -
The glue in question states it will not mend polypropylene. I think the Classic base housing is polypropylene. Please research and confirm.
O..
Hi cpolen350,
Welcome to the Bose Portable PA Community. I'm glad you found us.
Were you getting feedback from the guitar or vocal mic(s) or both?
Are you using the ToneMatch Presets? Which ones?
Did you try using the R1 Remote tone controls?
Hello! Thanks for answering! Was guitar only. Was using Preset for Taylor - was playing a Seagull. Didn't adjust anything on the Remote - guy from audience suggested I turn everything up a bit and only the guitar was giving me trouble.
Hi cpolen350,
cpolen350 posted:Hello! Thanks for answering! Was guitar only. Was using Preset for Taylor - was playing a Seagull. Didn't adjust anything on the Remote - guy from audience suggested I turn everything up a bit and only the guitar was giving me trouble.
Here are some suggestions.
Hi All,
I know this a old thread.
But, just for the record I wanted to suggest this small change.
since master out of t1 is line level TRS signal and L1 classic channel 1/2 accept xlr or TS signal .. I think it makes sense to put some pad at master out t1 .. To bring line level to mic level at classic when using trs to xlr cable..
ofcourse I am not an expert but to me adding pad makes logical sense ..
thanks
Xytiz
