L1 Model 11 Power Stand - light but no sound when first switched on
Bose product name L1 Model 11 Power Stand
Country UK
When the Power stand is first switched on, the light comes on but there is no sound coming through.  If I switch if off and then on again, there is sound.  It does this consistently, every time its switched on.  It's also noticeable that the LED is a bit dimmer than the other Power stand I have, not sure if this is relevant though.
Has anyone else ever had these symptoms ?  The stand still works OK but I'm a bit worried it may one day decide not to switch on at all!   Any feedback gratefully received
It's been doing this for some time now
Used with Yamaha mixer
Hi Tim,
Welcome to the forum! Thanks for joining us, sorry to see you're having an issue with the L1.
Have you had a chance to test the system in the past couple of days? And is the issue still apparent?
I think it's worth contacting the Bose support team directly to discuss this issue in more detail with a technical advisor. The team can be reached here.
