L1 model 11 x 2 into Samson time 16
I have 2 L1 model ll. I am doing a show soon and need to connect to bigger rig. I was thinking about positioning both L1 atvrear of stage either side and big rig woth or without monitors at front of stage. I am putting guitar
guitar, banjo 2 keyboards, and 2 mics into ystem. Can you advise on best way please
Graham
gen_ii,
You can absolutely put the L1’s behind you on both sides at the rear of the stage. If you do this then you shouldn’t need to connect monitors. The L1’s tend to feedback less than other loudspeakers but if you do start hearing some feedback you can try placing the L1’s at the center of the stage on either side while you play between them. The articulated arrays in the model 2 allow for you to hear them even when you are on the side of them.
I hope this was helpful. Good luck!
Thanks for the reply
would i still need the T1’s in the set up or should i just take line out from samson TMX16 into each power stand
Originally posted by West-at-Bose:
gen_ii,
Hello,
You could use the T1s if you want the Presets. There’s no harm in just using the TMX16 though. I think you should go with whatever is easiest for you.
If you use the TMX16, then as you said, just take the main line outs to each power stand (Left out to one, Right out to the other L1).
