L1 Model 1S
Hi!
I played an event outside this past Friday on a stage setup on a beach.  My L1 1s worked perfectly that night. When I set up for my gig the following night, there was no sound out of the column. I tried re-seating the column sections, retracting the legs on the stand, etc. with no luck. It powered on and sound was coming from only the B1.  My first reaction is to either try blowing out the connections or vacuuming them, but wanted to get your advice first.
Andy Russo
arusso59@yahoo.com
732-768-3973
NJ USA
Hi Andy!
If the system was used on the beach, it's possible that some dirt/sand (or possibly even some insects) have got into your L1 model 1S and are causing this problem. I recommend contacting the Bose Pro support team for further guidance.
