L1 Model II Power Stand red light on and off
when start the music after few seconds the  power base stands light green turns to red red and fan is working and the music stops.
Edit Subject: Previously "L1 model II"
Bose Pro Community Admin
Hi, Martin.
Welcome to the Bose Portable PA Community.  I'm sorry you are having a problem with your Model II Power Stand.
Martin posted:
This could be due to
  • A damaged bass module cable. That's the blue cable that runs from the Power Stand to the bass module (B1 or B2).
  • Connecting a B1 and a B2 at the same time
  • Damaged or failed bass module (B1 or B2)
  • A failed connection between the Power Stand and the Cylindrical Radiator®
  • Power Stand failure
Tests
  • Remove the blue bass module cable from the Model II Power Stand
    • If the red light cycling stops then the problem is likely a damaged cable
      • Open the connector ends of the cable and look for broken wires or a short-circuit
  • Remove the Cylindrical Radiator®  (the tower) from the Model II Power Stand
    • If the red light cycling stops then the problem is likely a connection to between the Model II Power Stand  and the Cylindrical Radiator®
      • The unit will have to be serviced.
  • Leave the bass module cable connected to the Model II Power Stand  and disconnect the other end from the bass module
    • If the red light cycling stops then the problem is likely bass module
    • The bass module will have to be serviced.
  • Disconnect everything from the Model II Power Stand. Leave it unplugged for a minute. Then connect only the AC power plug. Turn the unit on.  If the red light cycling continues, the Model II Power Stand will have to be serviced.
If you go through the tests above and you need to have the Model II Power Stand or the bass module service please Contact Bose Support.
From Bose: TO OUR CUSTOMERS
While our global call centers are facing disruptions and delays, you can still get 24-hour service for returns, exchanges or repairs by following one of the links below.
Bose Product and Technical Support - North America
Other Regions
