Bose product name: L1 Pro 8 and L1 Pro 32
Country: USA
Detailed description of the issue and steps to reproduce: Recently I have had an issue with my pro 32 where after setting up for a gig it would just randomly power down. Check all the cables, swapped out cables, and changed outlets and still had the same problem. It would stay on for 1-3 minutes then power down. Once I started playing it did stay on, but during breaks it would power down again. I usually run music via bluetooth during breaks, but it was unusable. A few days later I was playing a smaller show and took my l1 pro 8 out and it had the same exact problem. Even with nothing connected to the PA system it still would turn off.
When did you start to experience the issue? 2/9/22 Did it work correctly previously? Yes
Additional gear used (e.g. instruments, mics, FX pedals, etc.): Voice live 3, LR Baggs EQ and reverb pedal, Voodoo Lab Pedal Power X4, Earthworks SR40v, Martin D16, and Boss Wl-20L wireless guitar system, Bose t4s.
Where did you experience the issue? (e.g. home, bar, performance hall, etc.) At the Bar and at a winery.
Any troubleshooting steps you took: Disconnected everything then reconnected, put the PA on its own circuit, swapped out power cords,
What devices were you using that were affected and what version are they on? (Samsung Galaxy S9 on Android 11, iPhone X on iOS14, etc.) Samsung S20 Ultra
App Version:1.03-1490
Firmware Version: 1.0.2
