The simplest solution is to connect everything to the TV. Sadly this Lifestyle system does not support eARC so you would have to use the optical out of your TV to your Lifestyle system.
The problem with that is optical cables only send PCM 2.0, Dolby Digital 5.1, or DTS 5.1. They cannot send uncompressed audio formats to the Lifestyle system.
Not only that but a lot of TV's do not output 5.1 for HDMI sources connected to them only PCM 2.0 (be aware that sometimes internal TV sources like apps do output 5.1). So, before you do anything test and see if your TV outputs 5.1 or 2.0 using optic and a source you know outputs 5.1 via HDMI.
I would like to point out what cables can support what formats:
- RCA - Stereo (aka PCM/LPCM 2.0 )
- Digital Coax/SPDIF & TOSLink/Optical - PCM 2.0, Dolby Digital 5.1, & DTS 5.1
- HDMI - All above & Uncompressed Audio (LPCM 5.1, Dolby TrueHD 5.1, DTS Master Audio 5.1, etc.)
If you don't care about uncompressed audio & your TV outputs 5.1 you might just want to keep it as it is, but there might be better solutions.
Before I continue, I would probably purchase a harmony remote or something similar that can control the system and everything else connected (just wait for a sale as I did on Black Friday). Though you can use it with the included switch remote to change sources.
1. Get a device with two HDMI Audio outs:
Some devices support two HDMI outs like this 4K BluRay player.
Most cable & satellite boxes do not support uncompressed audio for their TV channels. Though some apps built into the system might. So this might be a great way to connect everything to your TV and use your Blu-Ray for the apps.
If you are like me and your TV does not output 5.1 but only 2.0 then connect your 4k video to the TV and send the SPDIF/Optical cable to your Lifestyle system.
This is why a universal remote like what I mentioned earlier would make using your system with this type of setup a lot easier.
2. Get an HDMI switch with 2 HDMI outs :
I found an HDMI switch with 2 HDMI outs that supports 4k @ 60hz... but as I said earlier it might help... I do not know if you can connect in a 4k source and have it send 4k video to the TV and if the audio will still go to the Lifestyle system or if the 4k source will make the system not recognise the signal. There is a chance that it might not and you'll get no sound at all... This switch might send HDMI audio-only as it includes a few options, but seeing as I do not have a 4k TV I cannot test this out for myself.
This HDMI 4x2 switch features 4 HDMI in's and 2 HDMI outs
- Connect your HDMI devices to the HDMI in's on the switch
- If you need more than 4 ports there are other HDMI #x2 switches out there
- The TV & Lifestyle
- Connect HDMI Out to the Lifestyle
- Connect HDMI Out ARC to your TV's ARC HDMI port.
- ARC is a special HDMI port that will send the TV's audio to your Lifestyle
This specific switch is currently sold out on Amazon but I found it on Ali Express. If you want a different HDMI switch just avoid Matrix switches. They allow you to send out different audio/video sources and could make using it a pain.
If you can find an HDMI switch with 2 HDMI outs and one only sends out HDMI Audio and no video then you know for sure it'll work. I did find another switch that said it has an HDMI audio out port, but you have to bulk buy it. So, it does exist, I just haven't looked that hard for one.
Now if it works as I hope it will with 4K sources :
Using this setup will still give you the full 5.1 surround experience you are used to as this is what your Lifestyle system is capable of supporting:
- Uncompressed PCM 5.1
- Dolby Digital
- DTS
- Dolby TrueHD
- DTS Master Audio
