Lifestyle 25 to Lifestyle 50
I have a lifestyle 25 with 2 zones plus a piggybacked 3rd via an sa2 amp which has stopped responding to all 3 remotes I have. I have tried all solutions for the remotes suggested on a previous post on here. It did start working and I thought I had a fix but was only temporary.
I am therefore looking to buy a second hand replacement Lifestyle 25 CD head unit, I  have also seen Lifestyle 50s systems for sale.
Question is the accoustimas connectors appear to be 10 pin on the LS50 whereas the LS25 are 8 pin. Is it possible to get adaptors to make the LS 50 compatible with  my LS25 accoustimas units.
Many thanks Steven
Bose product name
Lifestyle 25
Country
UK
I spent quite a while trying to get my head around this when I was researching a guide I made. I couldn't figure out why some systems supported Dolby Digital 5.1 and earlier models didn't, even though both were surround sound systems.
I later discovered a website https://myboserepair.com/lifestyle.htm which lists all the Lifestyle CD models. It showed me that systems like the Lifestyle 25 II had a Digital Coax input on the wire to the subwoofer (13 pin DIN)
While the previous Lifestyle 25 I did not (8 pin DIN).
As you can see the Lifestyle 50 also has a Digital Coax input (so it also has a 13-pin DIN).
Since the Lifestyle 25 series I & II both use the same receiver, the only difference is the connection to the subwoofer. So my GUESS is that you will just have to use the same subwoofer to receiver cable to make it work... but I do not know if it'll work or cause any issues.
It would be best if you either upgrade your subwoofer along with the receiver so you can listen to Dolby Digital 5.1 and use one of the suggestions in this guide to get the best out of your system. Or see if there is anyone around your area who is offering a trade-in to a new system (listed as Option 2 in this guide).
Don't forget that the Lifestyle 50's receiver is unusual as it is in two parts (C-1 aux inputs & M-1 interface) and required a touchscreen remote for it to work which appears to be hard to find and can break easily (they are 20 years old by now).
I would recommend you look for another CD20 receiver as, aside from the changer probably needing a replacement part ( 20 years old), oh and as the Lifestyle 50 also has a 6 disc magazine, I imagine this part would also need to be replaced in the Lifestyle 50. The CD20 is all in one and uses a remote that I would think is easier to find.
I do list some universal remote replacement options in this guide that would work with either receiver.
I hope that this helps answer your question. Let us know what you end up doing 🙂
Thank you Neonsnight, I think the conclusion is don't try to mix LS50 with LS25, I'll look out for a replacement cd unit for a 25.
Steven
Steven
I think it would work for the reasons stated, but I am not 100% sure.
I do think the CD20 is a better receiver when compared to the M-1 (with C-1 player) and while the CD20 remote isn't as cool as the M-1 remote, it'll probably last longer.
Though I would suggest you see if you have anyone around you that offers a trade-in service.
Thanks again for your extremely comprehensive answers.
Regards, Steven
