Hi All,
We have some custom set top boxes that deliver a mixture of satellite and IPTV. Having bought a number of Lifestyle systems explicitly for the ability to handle and integrate remote control for numerous HDMI sources, and take this duty away from the commercial Smasung 690U TV as well as add premium sound and hardbutton remote, it now seems I can't quite do what I assumed would be an easy, common requirement.
I have 2 sources:
1. LiveTV (this is a Set Top Box: Infomir MAG410 with custom APK and home page, but all MAG models share same remote control so unify settings for MAG323 work fine)
2. AppleTV4k
Having set everything up, my Bose Remote now lists 3 sources:
1. Set Top Box (which I would like to rename to "LiveTV", our custom mixture of Satellite and IP TV)
2. Apple TV
3. TV (which doesn't do anything as the TV doesn't handle sources anymore)
So, obviously I'd like to rename the top option, and remove the 3rd, which does very little. This is a 7* resort, with varying guests and not always tech savvy, but it's critical that the remote source naming makes everything very obvious and overly simple. Guests pressing "TV" and getting a "no signal" or black screen then calling guest services is not a good thing. I appreciate this is a commercial setting and I'm using consumer kit, but if we could the renaming as per the above, and stop "TV" from being displayed, the system would be perfect.
I've read a previous post on this, and sounded like Bose were looking at a firmware update to deliver:
Is this a feature update that is being actively worked on?
Many Thanks,
Dom
