I was using an Audix om3 through the top input when it suddenly cut out. I tried the second input with no sound still. Does the S1 Pro have a fuse? Any other ideas on what could have happened and how to resolve?
Hi, PattyJ.
Thank you for joining the Bose Portable PA Community. Welcome. I'm sorry you're having a problem with your S1 Pro.
PattyJ posted:I was using an Audix om3 through the top input when it suddenly cut out. I tried the second input with no sound still.
Let's do some diagnostics.
- Please disconnect the microphone from the S1 Pro.
- Follow this link and reset your S1 Pro ->
- Turn on the S1 Pro.
- Check the power light - does it come on (Blue)?
- Turn up channel 1 all the way. Do you hear a slight hiss?
- Turn the channel 1 volume back down.
- Turn up channel 2 all the way. Do you hear a slight hiss?
- Turn the channel 2 volume back down.
- Can you play music through the S1 Pro via Bluetooth? If you're not set up to do that, just skip this step.
- If you heard a slight hiss with steps 4 or 5, the S1 Pro is probably fine.
- Try a different microphone cable in channels 1 and then channel 2
- Try a different microphone in channels 1 and then channel 2
- Try connecting an instrument (e.g., guitar) in channels 1 and then channel 2
- If you didn't hear a slight hiss with steps 4 or 5, please remove the battery and try steps 4 and 5 again without the battery installed.
The S1 Pro does not have a fuse. The closest thing is the S1 Pro Reset.
If the S1 Pro remains silent through all the steps above, please call Bose Support. They will help you.
(U.S. and Canada only)
Other regions
