Minimum distance between 2 L1 compacts in a live perfomance
Hi,  I play in a duo and we have two L1 compacts, overall they work great.  Sometimes we play using both L1 compacts.  I noticed that sometimes it sounds like we are getting some sound interference, the two modules creating different sound waves that essentially collide.   When using two systems is there a specific minimum distance the two units need to be at?
I believe it's 20 feet minimum for dual mono, the link below is to an article that discusses this issue.
<dl><dt>Summary(from the article)</dt></dl>
  • Dual Mono - keep the L1s 20 feet (6 meters) apart or more
  • Multi Mono - every source is heard through only one L1, there are no issues
  • Stereo (pre-recorded music), distance between the systems is less critical because you are not sending identical signals to multiple systems
https://toonz.ca/bose/wiki/ind..._Distributed_Systems
Hi sjrippe, have you tried using each L1 Compact system discretely? You connect to one unit and your duo partner to the other - no interconnects between the two. This should eliminate the interference and should result in better localization, clarity and better feedback control. It is worth a try.
I play a Tyros 5 through one L1 Compact what is the minimum distance between speakers
Hi, keyboardken,
@keyboardken posted:
We are talking about the minimum distance between two L1 Compacts. If you have only one L1 Compact there is concern about distance.
Have I misunderstood your question?
Hi ST I am considering buying a further L1 Compact in order to get stereo sound from my tyros 5, when I play at home in a small room I was thinking of an L1 compact either side of my keyboard due to the fact I don't have the Yamaha onboard monitors would this be ok
Ken
Hi Ken,
Thanks, I understand now.
Keyboards and stereo are a special case because keyboard monitors are usually on either side of the keyboard.  A couple of L1 Compacts should be fine like that.
Hi ST
Thanks for the information I will now purchase
Ken
