Mixer cascade (3 T1 to 3rd party mixer)
Hi all,
could not find an answer to following question:
Is it possible to use my 3 T1 as submixers for mono sources and go from there via output trs/xlr-Cable to a 3rd party analoge stage mixing console like the mackie 1402 and from there to my 2 L1 ModII?
Background: 4 piece band with 3 stereo devices (2 keys, 1 kemper unit) and i would like to have all the benefits from T1 units.
Is that a wrong way to go?
Thank you
Hey mo PA PA!
This setup should be absolutely fine, as long as gain staging and levels at the sub-mix stage are all set correctly.
Thanks Dylan for reply,
since the mixers are all on stage, we keep an eye to the gain staging.
For bigger Events with FOH-tech, we are planning to cancel the mackie mixer and go directly to the stage box (partially from tht T1s)
