Need an advice on "Category selection" and "Real sound adjusting/tune" on T1 Tonematch
Hi
I 'm looking for an advice on how to set up/adjust/tune the sound on T1 Tonematch.
When I play music from the YOUTUBE of  my I-phone connected to the T1 Tonematch (channel 1 or 2),
-What is the "category selection" on the TONEMATCH should I select?.
-What are the best tune category selections should I have to setup and adjust.
Thank you in advance.
Andy
Hello Andy,
The categories are designed specifically for instruments. However, you can either fully disable the effects if you just want a clean signal, or you can adjust each individual effect - this all really depends on what you are looking to achieve.
Hope this helps.
