Need more channels
I this is the old “Coot”. I’ve been playing out a lot and find that some of my other friends will drop in and want to sit in. I am using 2 L1 Model II with twin bass on each side plus the T1. Channel one is for my vocals, CH 2 is for my digitech vocalist (harmonies), CH 4/5 is for my keyboard (Korg PA3X Arranger). So that leaves channel 3 which I usually use for someone who wants to sing. But there are others that bring their instrument and I have no where to plug them in. Any suggestions?
Hey Coot,
You can plug in an extra guitar into the analog input on each L1 Model II powerstand.If the guitar is an acoustic/electric with onboard preamp,your good to go,less any desired effects.You can also invest into a cheap small mixer an tap into the same analog inputs on powerstand.It helps if the guests know ahead of time so they can bring their effects or preamp if you don’t buy a mixer.
Thanks, I’ll give that shot. Since I have both L1’s daisy chained together I wonder which side it the guitar will come out of. Logic says the one it’s plugged into. We’ll see. Coot
Originally posted by Coot:
I wonder which side it the guitar will come out of. Logic says the one it's plugged into. We'll see. Coot
Your logic is correct,it will come out of the L1 you plug into.Be sure and turn the analog volume all the way down prior to plugging in,then slowly turn up to desired level.
