Pair of S1 Pro with Sub 2
Is it possibile to connect a pair of S1 Pro to a single Sub 2?
Hey StilNovo!
Yep this is possible - just connect your audio source to the Sub2, then use the Sub2's two line outputs to connect to each S1 Pro.
On the Sub2, I recommend selecting the 'HPF' option on the Line Out EQ for optimum clarity.
Hello StilNovo and Dylan_R,
Don't forget that the Sub2 and Sub1 have a special HPF optimized for S1 Pro's.  Hold in on the LINE OUT EQ button for four seconds to enable it.
Additional details, including a specific S1 Pro hookup diagram, are at this link.
