Here’s a interesting bug that one of my dealers found. I have confirmed it with the enclosed configuration files.
If you put a parameter set list on the display and load in more than 9 parameter sets, when you select 1 - 9, the parameter set selected stays visible in the display. When you select 10 or higher, it displays for a second and then goes blank.
I have tested this on the iOS app on in iPhone (iOS9) and on the Windows App (Win7-64) and the results are identical.
Hi Brian,
Thank you for testing it also.
I logged it.
