Perfect power for AMM108 and AMS115
Hi I have one AMM108 and one AMS115.
Which PowerMatch you recommend?
How many watts for the AMM108 and how many watts to the AMS115 to obtain the maximum SPL of the system?
Thanks in advance.
Joaquin
https://pro.bose.com/en_us/products/loudspeakers/point_source_sound_reinforcement/amm/amm-108-multipurpose-loudspeaker.html#ProductTabs_tab2
https://pro.bose.com/en_us/products/loudspeakers/point_source_sound_reinforcement/amm/ams-115-compact-subwoofer.html#ProductTabs_tab2
Ji Juaquin,
For a single AMM108 and single AMS115, you could use a PowerMatch PM4500N.
The bottom line is- the rated peak wattage on these shouldn't be the only factor to base amp power on. (otherwise you'd at least need a PM8500N just to hear a very slight increase in peak spl)
For both products, use v-bridge low-z wiring and output configuration.
ChrisJ-at-Bose
