Pls provide a diagram: T4S connected to a pair of L1 Model II/B2 Base & a pair F1 812 with 1 F1 sub
Hello mnstrljb!
Thank you for your post.
I recommend connecting the T4S to the F1 812 speakers using 2 x 1/4" cables:
Then, connect the T4S to the L1 model II power stands using two ToneMatch cables:
The F1 subwoofers and B2 bass modules can be connected to the bass module line outputs on the F1 812 speakers and L1 model II power stands, respectively.
Thank you, Dylan. How far apart from each other would you set them up on stage?  Would you care to provide a drawing front/back and side to side? Is there a minimum distance to prevent sound cancellation?
Thanks you, your help is much appreciated!
mnstrljb
Dylan,
How do I connect one F1 Subwoofer? Do I go from the T4S (L and R) to the Subwoofer, then out to Left and Right F1 speakers?
mnstrljb
Hey,
I'd recommend connecting the T4S straight to the F1 812 speakers, then connecting the 812 speakers to the F1 subwoofers via the line outputs like this:
Once the F1 subwoofers are connected, set the EQ switches on the 812s to 'WITH SUB'.
Unfortunately, I only have one (1) Subwoofer. So can I connect from T4S (L and R) to 1 Subwoofer. Then from 1 Subwoofer to L and R F1 speakers?
Hi,
This setup would work fine as well - you can connect the T4S to the F1 subwoofer, then connect from the F1 sub's line outputs to the F1 812 speakers with XLR cables.
So, I used the recommended setup connecting the T4S to the two L1 model II power stands (with the speakers spaced about 20 feet apart at front (facing the sun) and back) using two ToneMatch cables at an outdoor festival gig around noon yesterday. I did not connect the two F1 812s and subwoofer  at this time. The sound was great for about 30 minutes after which the power to the T4S completely died. I switched the ToneMatch cables (L and R) connected to the T4S and its power went back on. Another 30 minutes it died again. This time we used a power supply connected to the Power Port on the T4S and reconnected the other L1 model II to one of the Analog Outputs and the sound was great the next three hours.
Thanks in advance!
