jak dobrze uzywac ze soba Ts4 - / uzywane 4 mikrofony Vcalowe /
z Ts8 / che uzywac uzyc 1 i urochomic na nim dyley dla wszystkich mikrofonów .... czy jest lepsze rozwiazanie?nie chce uzywac wejcia 9,10 bo nie ma go na wyjsciu aux.
I'm sorry I can't answer you in Polish. I have used an online translation to read your question.
Slawomir posted:
how to use Ts4 well with each other - / 4 Vcal microphones used /
with Ts8 / I want to use 1 and run on it dyley for all microphones .... is there a better solution? I don't want to use the 9,10 input because it's not on the aux output.
If you need the signal from the microphones to be heard through the Aux outputs, then you must use channels 1, 2, 3, 4, 5, 6, 7 or 8. The Aux inputs 9/10 can not be sent to the Aux outputs.
